Old 11-03-2012, 02:49 AM   #7 (permalink)
nmtmechengineer
Sexy Beast - '93 Nissan Altima GXE
Updates
Hi I been some what busy, cold weather is having negative effect on gas mileage. Although I have fixed gas leak from old fuel lines, and oil leak on crank pully. In addition I added the wheel skirts, re adjusted the rear diffuser angle to 5 degrees from 8 degrees. Then added some more length to the rear deck spoiler. I'm in the process of designing a rear kamm back that will extend to the rear spoiler. I want to use some clear plastic for part of the kamm back. I have plenty of aluminum and coroplast to make the kamm back. Im also considering converting the car to manual, I have done this two 3 other cars in the past. I will post a picture. I was thinking about posting some pictures for build of the kamm back for the sedan. I like the way 2000neon built his.
