Old 11-03-2012, 08:39 AM   #85 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
If you can find room to mount the surface mount sensor, you can use it, but if i remember correctly, it become impractical because it needs to be so far away from a bus bar wide enough for 2000A.
But in short, yes you can use it if you want to. There will be an option to enter the amps/volt into the controller so it knows what range it can measure.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
The Following User Says Thank You to adamj12b For This Useful Post:
sawickm (11-03-2012)
