Old 11-03-2012, 10:17 AM   #16 (permalink)
ps2fixer
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
Got 43mpg on the trip to work (night time, below freezing), I found the "hidden mpg mode" again. Maybe this car has the same ecu/logic as the lean burn models overseas. Basically to get into the mode, I have to do 2 steps...
Speed up to ~50mph so I have time/speed to loose adjusting to get into the mode
Let off the gas to a 5.x reading for the map sensor (timing drops from 39 to 26)
Lightly press on the gas and target 6.6 map reading (keeping the timing at 26)
If I go above 6.9, it instantly jumps to 7.9... and the timing jumps back to 37-39.
I have a couple of DVR video recorders comming in the mail, so maybe my first video I will show what exactly is going on hopefully learn what is really happening. My guess is either a lean burn mode, or a spark knock is detected @ the lower map readings and it pulls back the timing for that range and the maybe the map sensor is bad/sticky. What ever it is, I'm going to try to stay in that mode again more often, been a long time since I really tried, but the resulting mpg is much higher per trip (upto 50-55mpg in summer).
