Old 11-03-2012, 11:37 AM   #86 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
For a 1 inch wide bus bar that is 1/4" thick, a 1/8" thick PCB (that acts both as the spacer and board you solder the chip to) gives a range of about -1200, to 1200amp. So, you would need another 1/8" spacer to get close to 2400amp. That's only for the Melexis HB, though. The LB needs probably 1.5" or something ridiculous.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
sawickm (11-03-2012)
