Old 11-03-2012, 02:25 PM   #38 (permalink)
aerohead
Bug
Since the Beetle is kinda tall with respect to it's width,then consider using a symmetrical wing section as your 'Template' in plan view.
*On the last page of the 'Aerodynamic Streamlining Template Part-C' thread is some data on sections.
*The second pictorial drag table has the lowest drag section.It has a chord-to-thickness ratio of about 3.9:1.You can measure it off the table.
*Anything 'thinner' or more 'bluff' will have higher drag.It is the drag MINIMUM.
If you'll match your roof curvature to the sides you should have zero longitudinal vortices.
If you're going to do rear wheel skirts,then I recommend you leave their width alone,but add fairings in front of,and behind them to soften the pressure spike which they cause which will impact the boat tail.
If you're going to have exposed wheels and run MOONs,then I recommend you reduce their frontal area by trimming them and extending them down close,and flush with the outside of the wheels.
If your tail extends only as far as the rear edge of the rear bumper you should see Cd 0.244 territory as with the 1934-1/2 Chrysler DeSoto Airflow experimental.
The inflatable tail will get you lower.
*The Rumpler Tropfenwagen only achieved Cd 0.28.You can do better.
*The Dymaxion Car is estimated at Cd 0.25 by one source.You can do better.
BamZipPow (11-03-2012), freebeard (11-03-2012)
