Old 11-03-2012, 04:18 PM   #39 (permalink)
freebeard
Thanks for your comments.
It has a chord-to-thickness ratio of about 3.9:1...
*Anything 'thinner' or more 'bluff' will have higher drag.It is the drag MINIMUM.
I'm looking for something in the 'wake-filling/attached flow' range. But maybe more aft length would compensate, is some general way, for the less than optimum fore-body. A fineness ratio of 4 suggests ~160" of aft body without truncation.
If you're going to do rear wheel skirts,then I recommend you leave their width alone,but add fairings in front of,and behind them to soften the pressure spike which they cause which will impact the boat tail.
This is exactly where I'm headed; treating the windshield and back as one case, and the rear fenders and back as another. Maybe on the back side of the front fenders I have an opportunity to use Coanda nozzles.
I'm headed out right now to take another pass at the mock-up, and also my aerodynamic garage.
