Thread
Lean burn Honda Civic sedan: 93 Civic d15z1 swap into LX 4 door (VLX)
11-03-2012, 05:47 PM
14
permalink
slownugly
Burn lean and prosper\\//
VLX
- '93 Honda Civic VLX
90 day:
51.1
mpg (US)
got that little project done. was very easy and took maybe a half hour. (once i found the cruise control letters i cut out and proceeded to lose) i already traced the wiring on the back of the cluster circuit board to where the connector pushes in and which terminal i need to install the pinout into. now all i have to do is switch the original lx cruise control wire into the new pinout i just made and wire the shift indicator light wire from the ecm to the plug for the corresponding connector on the cluster and voila it should work fine. the empty spot where i put the cruise bulb looks like it gets a key on power and the cruise control module grounds the light bulb when it sees that its working. ill test for power and ground and hook a ground up to the wire to make sure it works properly and to show everyone how it will look.
slownugly
View Public Profile
Send a private message to slownugly
Find More Posts by slownugly
