Yeah, that's what I figured. I'm thinking about taking it back to the beginning of the wheel wells. It'll be about the same size as the box, and I'll have the middle section of the bed open for easy access. I think if I stack firewood up inside the extension I'll get nearly as much in the truck as I did using the full bed and stacking it just to the top of the bed. Of course I need to put something in to protect the back glass. I will have a board run across the bed at the cab. When I haul plywood the board and my box will make a "shelf" to lay it on, and I can just strap it down. Another advantage over a full bed cover is visibility (when I'm not hauling firewood anyway).
