Originally Posted by Honda100
Also, I had a Mitsu Lancer a while ago which used the variable intake runner "thingy" which broke. It got stuck on "low speed" setting, and the mpg only went up maybe by a half an mpg, and it's questionable if it was down to the intake or not.
If it was stuck on the low speed setting, then I'd think it wasn't that, that affected your MPG...Unless you're typically cruising in 3rd gear at 70mph
![Wink](/forum/images/smilies/wink.gif)
