The throttle plate restricts air at the TB. If you fit a smaller TB you will have more restriction there so you will open the throttle a little more for the same power. This will result in the same amount of air going in so the computer will send in the same amount of fuel.
The biggest change you may note is that it takes more "foot" so you will have to make your self push harder to go as fast as you did before. You may see an increase in mileage but it will be more of a driver behavior thing than from any magic happening at the throttle body.
A similar effect could be gotten by putting a heavier spring on the linkage.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
