Old 11-04-2012, 02:08 PM   #20 (permalink)
nbleak21
Adventurist!
CLaero - '97 Acura CL Premium
90 day: 34.59 mpg (US)
CR-v - '03 Honda CR-V EX
90 day: 26.52 mpg (US)
Originally Posted by tastypotato View Post
I've also been playing around with the whole Lean-Burn mode. The car doesn't really want to go into it when I get off work (11PM) and will take about 20 miles of driving before I can get it to engage. However when I leave FOR work at 1:45PM as soon as I hop on the freeway it'll engage. Maybe I'll give that Marvel Mystery Oil a shot?
I think there's probably a couple of factors at play here: Ambient Air temp & Engine Temp
When your car has been sitting out all day, warming up with the weather (and even more so when the sun is out) you're engine will warm up to operating temp a lot sooner then it will when it's cooler out, and the sun has gone to rest.
Also, with the cooler evening air when you leave work, it will be denser, meaning it may be harder to hit the parameters to go into lean burn mode.
monitor your IAT's and Coolant temps relative to initial lean burn engagement to verify.
As for the MMO, give it a shot and report back to us!
Also see if you can compare it w/ MMO to the above stated, as well as general O2 readings across the board. If it drops the 02 readings throughout the range, then perhaps that will help with my faux lean-burn dilemma, too!
'97 Acura CL 2.2L 5spd
'03 Honda CR-V 2.4L EX 4wd Auto
The Following User Says Thank You to nbleak21 For This Useful Post:
buck (10-31-2013)
