Old 11-04-2012, 02:52 PM   #10 (permalink)
oil pan 4
The larger inverter may have a higher stand by load.
Also if you go with a deep cycle or marine battery you should get a deep cycle marine battery charger and use it to give the batteries a good charge at least once a week.
The Deep cycle marine batteries like to see up to 14.8v when they charge.
Then every month or 2 they should be equalized and have water added, equalization charge goes up to like 16 or 18 volts.
