Horsepower= torque {lb_ft} * RPM/5252. Universal hot rodding formula.
The following assumes the same gear ratio:
Torque required is directly proportional to drag force, and therefore, proportional to the square of the speed.
RPM is directly proportional to speed.
Suppose a car requires 35 lb_ft torque to maintain 50 MPH, and is running 1500 RPM.
35*1500/5252=9.996HP
Same car requires (100/50)^2 or 4times the torque (140 lb_ft) to overcome the drag @ 100MPH. It's also running 3000 RPM.
140*3000/5252=79.969HP (8 times what it takes to run 50 MPH).
Maybe someone else can explain it in simpler terms.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
