Old 11-05-2012, 12:01 AM   #1 (permalink)
BobEdwards
Question Dual Battery voltage controller?
Trying to decide between a 96V or 144V system. Then thought "why not both"?
If a controller (OpenRevolt?) could be modded to allow "normal" motor operation at (say) 96V (30 x LiFePO4 cells, say 90AH), then, when the pedal is to the floor, switch in an additional 48V (15 x LiFePO4 cells, say 40AH) that would give a power advantage whilst saving some battery cost, some weight saving and some space saving.
Would require 2 sets of MOSFETs and drivers, but only one (modified) controller. Would also probably need two separate chargers.
As a bonus, if you are out and about and run out of "main" battery, a contactor could be used to switch over to the bank of "reserve" cells so that you can "limp home" (or to the nearest charging place).
Or am I missing something?
