Originally Posted by ps2fixer
I thought the balance shafts delete is pretty extreme as well, lucky my corolla don't have one, but the Camry does... HUGE difference in how smooth it runs, not sure about power/mpg relating, I guess it should rev quicker with less effort if everything is done right.
I think I read somewhere online that someone had deleted the balance shafts, and found no detectable change in power output, but it was a hell of a lot rougher.
Do you have a 1ZZ-FE? All I know is that my 1ZZ powered car vibrates like crazy... no balance shafts would sorta explain that.
Originally Posted by ksa8907
i second the advise of changing your gearing, a 2.3 I4 is a decent size engine and unless your car is quite heavy i would guess that 1800-2200rpm @55 would be pretty good.
3000rpm at 80mph is 1500rpm at 40, 2250rpm at 60mph. That's pretty good gearing...I can't think of another 4 cylinder car with a longer cruising gear than that. The CL is not even a very small car either.
