Open BMS for high voltage LiFeP04
Hi all,
I have been reading Ecomodder for quite a long time, however never posted here.
I am converting a car to electric and I am using a DC BUS Voltage of 600VDC.
I will have a string of 192 LifePo4 Cells and I am looking into a decent BMS that allows me to check the status of the batteries, like lower and higer voltage cells, etc.
I am happy with 4 arrays of 154V.
I have looked into the Open Revolt BMS project but I cant find a lot of information on where to get the PCB´s. They are also made to fit large 100Amps batteries. As I plan to use 10 or 20Amp Cells I would like a central BMS, instead of a battery attached one.
Can anyone give me some advice on this?
Thanks, Carlos
