Old 11-05-2012, 05:11 PM   #2 (permalink)
nbleak21
Adventurist!
CLaero - '97 Acura CL Premium
90 day: 34.59 mpg (US)
CR-v - '03 Honda CR-V EX
90 day: 26.52 mpg (US)
In regards to the TB, yes, your exu will adjust for the larger TB, via o2 sensor, but generally allows you to run slightly leaner due to the TPS offset.
I will likely be doing the same with my F22 Acura. I doubt you'll have any negative effect running the b16 TB.
'97 Acura CL 2.2L 5spd
'03 Honda CR-V 2.4L EX 4wd Auto
