Old 11-05-2012, 07:14 PM   #8 (permalink)
Chris D.
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
I got the tape that's designed for it.. if the tape touches itself, you pretty much throw it away and start again because there's no unsticking it. I'm not sure I'd recommend the bedliner, it mite not stick well to the plastic, the plastidip stays flexible and it will easily peel off if you change your mind.
It just looks like its taped together every 4 to 5", your not missing anything.
You start from the edge and work your way in.
You have to massage it with the heat gun till it looks good and tight..
