Originally Posted by HydroJim
If you look at a metro, check the part of the frame called the "frame horn" which is where the front control arms attach. That is the most rust prone area and basically ruins the car. Unless you're into welding?
EDIT: based on your last reply, I assume you already know about this, so nevermind
I would second that my buddy hit a small pothole going 10mph in his geo and ripped the control arm off the frame horn.
