Old 11-06-2012, 09:11 PM   #15 (permalink)
nbleak21
Adventurist!
CLaero - '97 Acura CL Premium
90 day: 34.59 mpg (US)
CR-v - '03 Honda CR-V EX
90 day: 26.52 mpg (US)
Thanks for all of your replies. Yes, as stated, My Transmission is already geared pretty low... I just haven't started driving more conservative MPH yet (because I am currently fine-tuning my VFAC for fuel economy before hitting the hypermiling techniques hard)
Originally Posted by 3-Wheeler View Post
1) A bigger engine will have more surface friction due to piston area, longer skirt length, and so on.
Yes, I suppose there will be more surface friction due to the increased diameter (approx 1 percent [273mm dia vs 270mm] per cyl) though the piston skirts designed for the k24 engine are also smaller, and are coated to reduce friction so I feel those losses will be mitigated.
2) It will also have higher heat losses to the outside world because of the larger surface area.
I'm not quite tracking what you mean by this, can you explain further?
3) A bigger engine will require more fuel because there is also more volume to fill, due to the larger displacement.
I am running a VFAC, so I have the availability to lean the engine out at lighter loads.
4) A larger engine usually weighs more, so there will be more losses when accelerating due to higher mass.
The engine blocks are virtually the same in regards to weight as they are principally the same design, and the reciprocating parts (factory rods, and K24 pistons) are actually lighter then the factory ones in my F22
5) An engine with a lower TPS value will have more pumping losses because of the higher vacuum level in the intake tract. This is an inherent advantage of diesel engines; i.e. those with no throttle plate.
Under general principle, yes... but the design of the intake tract can greatly effect where the pumping losses have their greatest effect. In fact, the observation that sparked this thread in the first place was that I seem to have less pumping losses at 3100rpm then 2800 with my current engine, as the TPS requires less opening to maintain a higher speed then it does lower.
This leads me to believe that the sweet spot may of the IM may be at approx 120cfm, so the 150cc increase in displacement would drop that RPM for the same volume from 3100 to 2900rpms
'97 Acura CL 2.2L 5spd
'03 Honda CR-V 2.4L EX 4wd Auto
