The simple way to reduce duration and valve over lap is to increas valve clearance.
The stock final drive is 15T/44T, the furthest [available] from that is 17T/34T.
At 70 mph the change in final drive will drop the rpm from 5200rpm > 3500rpm.
The stock FE is 48mpg combined.
