Old 06-11-2008, 05:34 PM   #74 (permalink)
diesel_john
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
Originally Posted by dcb View Post
I do have something that is pretty cheap in mind for the mechanical diesels, but you have to install a throttle position sensor and a rpm or pump rotation sensor and a speed sensor, and I or someone has to teach the guino how to make sense of it.
I'm also thinking about just using a function like speed/(throttle position*rpm) for my bike too, to see if it is reasonably accurate.
the cam pulley or pump pulley bothe have 6 or 8 spokes in the pullies. and they are steel so would be a good candidate for an old cam position sensor.
The only information regarding resolution is "0.1l/min @ 1000rpm." Might be worth a look...they are cheap enough
How cheap are they? my flow range is 0.1 gal/hr to 3.0 gal/hr.
When i get the two cylinder going the range will be about half that.
