Depending on how you drive, disabling or avoid getting the vtec to kick in would be a start.
The newer Insight uses like a 11 to 1 compression with its fancy 2 plug per cylinder spark plug setup. It doesnt have the torque Id expect with such a high cr, all the power is around 5 grand unless you got the IMA system enabled and a full charge.
