Old 11-07-2012, 08:00 PM   #65 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
I'm curious to know if the dud you discovered had been otherwise "hiding" behind an acceptable looking resting voltage.
All of these particular batteries rest at 12.77-12.83V fully charged. This one was exactly the same. It even passed my 1/2CCA (350 amp) 15 second load test, ending at 9.7V (minimum is 9.6V). When I used our little handheld battery tester at work it showed "Good Battery", not that I put any faith in that thing. I think it just measures battery impedance or something.
I ended up replacing it with a "fresh" one today and the results were nice climbing the hill on the way home. This is my strongest battery pair now, aside from the two AGMs. This hill has me at FULL throttle in second gear at 55-56 km/h for about 1-1/2 minutes (I haven't actually timed it ever - maybe it just seems like that long as I anticipate my tiny motor going up in smoke!). The Alltrax controller delivers full current all the way up (until I run out of volts, of course) - pretty impressive, I'll say.
PS: I'm going to be in Vancouver over Dec/Jan this winter. I'd love to get a chance to see your car while I'm there.
Definitely. PM sent.
On another note, I have ordered all my bits to build my PWM field current controller addition:
-24-72V 100A Kelly Controller
-Hall effect amp transducer with 0-5V output
-Various resistors, capacitors and potentiometers to fine tune things.
Simply put, the amp transducer will measure armature current and signal the PWM controller accordingly to a max of 50 amps at full armature current. I will also employ a simple circuit to ensure a minimum field current of 10A any time the throttle is depressed (activated by the idle microswitch) to avoid brush arcing. (I have experienced audible brush arching with only 12V at 72V and full current and it makes your stomach turn).
It really sucks that I have to do all this since I bought what I thought was a used series wound motor but was sent a sepex instead. I should have sent it back in the first place, but I'm into now. At least I'm learning!
