Originally Posted by Daox
What parts are needed to attach a sprocket to the crank with the freewheeling mechanism?
Here's what you need.
1) one freewheel crank set (
Sick Bike Parts)
2) one front freewheel bearing (
Sick Bike Parts)
3) one extended length crank spindle (your stock one wont work because you will be extending the attachment point for your crank arms to fit the additional sprocket. You will have to measure for this, each bike varies)(
Sick Bike Parts)
4) 90 tooth #25 sprocket (
#25 Sprockets for Electric Scooters and Bicycles - ElectricScooterParts.com)
5) bolts and nuts (you pick the size, I went w/ M5)
