Old 11-08-2012, 12:15 PM   #27 (permalink)
Michael Moore
Originally Posted by serialk11r View Post
I'm counting like 36 teeth or something on the cams, so one entire tooth might not be so bad at 10 degrees.
The cams turn at 1/2 engine speed so 10 cam degrees is 20 crankshaft degrees.
It usually isn't difficult to slot a bolt-on cam sprocket to allow timing adjustments, and there are aftermarket sprockets for many sport bikes that come pre-slotted.
cheers,
Michael
http://www.eurospares.com
