update
Tonight I finished the Kammback I ended up making it extend to the rear spoiler edge, Wired up a brake light for it and used my clear plastic from home depot 30x36, braced it down the middle with angle aluminum I was going to use to secure a subwoofer in my camaro.
After doing that I ended up making the rear cavity extending from the edge or the sides I used some clear plastic so the brake lights are visible from the sides. I need to modify the Kamm back so I can see out the sides because I noticed there is blind spot. Angle starts at 12 degrees then finishes off 14 degrees. Sides angle starts at about 5 degrees then tapers to 10 degrees at the end. I noticed the rain slowly moving down the glass tonight it looks neat to say the least. I still need to radius the rear cavity on the bottom sides it is square for the time being.
I compared the length of the car to my 2008 impala and the impala is still approximately 1.5 feet longer than the altima.
