Thread: Reverse Trike
Old 11-10-2012, 10:15 AM   #2 (permalink)
groundflyer
Originally Posted by HydroJim View Post
If you were to build a reverse trike car with the engine in the front and front wheel drive, how would you handle the rear wheel? It needs to have a functioning hydraulic rear brake and a manual parking brake.
Here is what I've come up so far:
By using the rear wheel assembly from the donor car, I can be confident that the brakes and emergency brake will be easy to assemble and I won't run into any problems.
Look at youtube reverse trike alot are that way
