Thread: Carb rough idle
Old 11-11-2012, 02:45 AM   #9 (permalink)
christofoo
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
EGR is fine
It looks like I'm seeing an MPG improvement after the AAP vacuum line plug, especially for this time of year. I still feel the engine is subjectively smoother. Later on I'm going to reread the plugs, too.
In other news, I ran an EGR test today. It's working fine. Test method: using a hand vacuum pump with gauge to verify a) the EGR valve diaphragm holds a vacuum, b) the engine dies if the EGR is opened manually during idle. Separately, I verified that the EGR diaphragm moves when the engine is reved. That about covers it?
So apparently my hunch was wrong, no EGR fault.
