Old 11-11-2012, 09:55 AM   #150 (permalink)
NeilBlanchard
This form is going to be the core of the working prototype, ideally. I need to test it and then make adjustments before doing a second one. Or, if it all works great, then I could make molds from this and go from there.
I'll try to find a flexible rubber block, I think; and the paint method sounds like a good one. I'm only going to be able to do peel ply fiberglass, so perfection is not likely. Some of the inside of both the passenger compartment and the motor bay will likely have to be sprayed in and then use peel ply as possible.
