Originally Posted by takarp
Maybe you misunderstood me. I know it is normal, when I stop the l/km goes 999999, but the avarege is also changes.
Average has to change when you stop, the shorter the trip the bigger change you'll see. That's normal.
How can the calibration done? When I stop at a traffic light my tank average is rising!
You don't need anything more than this:
Mpguino calibration - EcoModder
Are you using the 0.86 r202 version cpp file from code.google.com, or you have any better metric version?
I was using v81metric (canadian) and v86 both worked just fine. For now I'm planning to connect MPGuino to my Berta diesel and it requires some changes.
What do you think about the vss problem over 60 km/h?
I think that's the problem of VSS signal. You may try to use shielded cable for VSS signal, or you may need to amplify the signal.
Take a look here:
http://ecomodder.com/forum/showthrea...tml#post334154
