Old 11-13-2012, 10:12 AM   #15 (permalink)
PaleMelanesian
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
I have a long hill I tackle every day. It's about almost 1/2 mile long, ~3% grade. It's shallow enough to gain speed in 5th gear. I note the change in trip mpg from bottom to top each day. It's at the same point in my commute, so that's a consistent mark. The best approach, that loses the least mpg, is the old "slowest speed in top gear". If I start the hill at 25 mph in 5th gear (1000 rpm), hold 80-85% LOD, I accelerate to the 45 speed limit at the top, with the least mpg lost. Other gears, higher starting speed, lower LOD, all give worse results.
The Following 4 Users Say Thank You to PaleMelanesian For This Useful Post:
Gasoline Fumes (11-14-2012), KamperBob (10-24-2022), mikeyjd (05-23-2013), wmjinman (11-13-2012)
