Old 11-13-2012, 01:51 PM   #17 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
I trust you've seen this:
http://ecomodder.com/forum/showthrea...eet-19126.html
So you're driving the car? What kind of mileage are you seeing and under what kind of driving?
The only legit driving was done bringing it back home (which was lower than I have experienced before under similar test drives in other insights), the driving done now is short slow test trips which I can't really say is real driving given the temperature and the distance and the idling involved while I tweek things and verify voltages.
I figure 14" RE92's would work great on the 15" cobalt as long as I use a scamguage to correct for them but no telling without a test, they would also work great on the ZX40 but I would have to cut the front fenders out and not turn real sharp Might fit the rear though.
My C-car space savers do glide further than typical 155/80r13's, but again we are talking a 2500lb rated tire with maybe 400lbs at most sitting on it so RR is again likely less important there as well and of coarse 155/80s on a c-car probably causes other problems that make more drag anyway, that and the 155's I have available to me are very likely not LRR at all, probably made to be cheap.
Ah well
Cheers
Ryan
