Old 11-13-2012, 04:55 PM   #21 (permalink)
Formula413
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 37.4 mpg (US)
he "forced charging" part is normal after doing that procedure on the pack: The computer's memory of the state of charge (SOC) no longer agrees with the actual state of charge. So when it detects the "extra" juice on board, it needs to recalibrate the pack (by forced charging to try to "top it up" and reset then the battery SOC gauge).
I should clarify that part. It did the same thing it always does if the 12V battery has been disconnected. After starting the car it showed 4 bars of charging for about 2-3 minutes, after which the charge/assist gauge went back to the center. I did this with the car sitting in the driveway. Once I started driving the car it provided weak assist at first, then stopped providing assist and went into forced charging.
