Old 11-13-2012, 06:18 PM   #14 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Good thing you've cut back the width of the front spoiler / air dam, and put it far more vertical.
It doesn't need to be too wide, as the air will be pushed out well beyond its edges anyway.
If the air dam is angled to the rear (i.e. bottom more aft), you'll still let air be pushed under the car - which is what you should be trying to avoid.
