Old 11-14-2012, 04:15 PM   #152 (permalink)
nbleak21
Adventurist!
CLaero - '97 Acura CL Premium
90 day: 34.59 mpg (US)
CR-v - '03 Honda CR-V EX
90 day: 26.52 mpg (US)
If peel ply works the way I think it must (never used it); a flexible metal or rubber blade held at a low angle should get a good result. As compared to a paint brush or something.
Correct, though in the initial wetting, using a paint brush to "dab out" the bubbles in the fibre glass as you would in the more traditional method of glassing will help considerably with prep of the peel ply. Otherwise any small bubbles when pushed out with the bondo blade will further deform the uniformity of the fibre glass.
'97 Acura CL 2.2L 5spd
'03 Honda CR-V 2.4L EX 4wd Auto
