Old 11-15-2012, 09:18 AM   #16 (permalink)
YeahPete
TheCav - '04 Chevy Cavalier LS
I agree w/ Metro. If your tapping the holes where you say you are, it shouldn't throw off the balance. You should be able to find a cheap tap set easy.
Make sure you use screws that are aluminum. Steel and alluminum react and corrode over time. Also make sure your wheels are alluminum and not some different metal and find the reactive characteristics of the different metal on metal contacts.
The Following User Says Thank You to YeahPete For This Useful Post:
WesternStarSCR (11-15-2012)
