Originally Posted by Gealii
would duct tape suffice for holding on a coro kamm? i'm not ready to drill holes in my roof quite yet
My boat tail's structure is aluminum drilled to the body but its skin seams are duct taped. You just have to manage the rough ends (where you rip it off the roll) so the air doesn't catch them. It helps to cut curves into the ends with a razor. Also, if you're layering, put down the rear-most tape first and work forward.
