Old 11-15-2012, 11:34 PM   #60 (permalink)
Hilly-Billy-13
Futurlec sensors
Originally Posted by rodeo1314 View Post
I just purchased a few of the FLOWFUEL30L0 flow meters and I am having some trouble reading the output signal. How are you guys getting a reading? My application is not in a car, it's an inline fuel measurement system for a dyno. I'm in the testing phase right now, I just got the meters. I can't figure out how to read these pulses and make it a useful signal that I can read.
rodeo1314
The Futerlec & most low cost fuel flow sensors use a digital output "Hall Effect" sensor. They're defined as an open collector output, what this means is the 3 wires are hooked up as follows Red goes to the positive side supply, if your using a Arduino or similar, use 5 Volts, the Black goes to the minus side of your supply. The you need a resistor between the positive side of the supply and the white wire which is your output. I've seen values from 10 K on down, some arduino pins have a pullup resistor as an option. I haven't received my sensors yet so I can't say for certain what value of resistor is needed.
Bill
Oh yes back in the mid to late 70's & early 80's I did some work on Dyno instrumentation I wish I'd had access to the sensors we can get now.
