Thread: Reverse Trike
Old 11-16-2012, 06:56 PM   #19 (permalink)
freebeard
the wheel geometry is just too unstable
At the limit, a nose-heavy four wheel car wants to become a three-wheeler anyway.
With 66/33 weight distribution and the suspension sorted out, the rear wheel should swing out and track behind the outside front wheel. A longer wheelbase helps, but creates problems parking, that why I suggested the variable wheelbase. I don't expect you to try it, it's just a thought experiment.
The biggest problem I see is the lower rear corner of the door window glass when it is rolled down into the door. That is the constraint on plan taper in the lower body.
