Old 11-17-2012, 08:49 PM   #8 (permalink)
nickdigger
Originally Posted by AndrzejM View Post
I've found interesting line in the code #953
Maybe that's the reason for misreading? Try to uncomment it and check if the readings will be accurate.
EDIT: It won't help... I think it's the dispadj & dispadj2 parameters that we have to taka a closer look at.
I believe there was some confusion in the code, with those two parameters. When dcb switched to 20mhz, he only tested the code for that clock speed, but the parameters were untested for 16mhz users. From my recollection, one of the values was wrong. If you search the forum here for 1250 or 125, you should eventually find a post with the answer.
