So if I'm reading things right...
1. With a weight distribuion hitch I can handle as much toung weight as the load capacity of the vehicle.
2. As long as I have enough power to pull the trailer through the air.
3. As long as I have enough cooling (particularly on an automatic transmission)
Then I should be fine.
So to be able to smoothly trailer my 3000+ lb Jeep approx 200 hp, upgraded transmission cooler, and trailer brakes?
