Thread
Lean burn Honda Civic sedan: 93 Civic d15z1 swap into LX 4 door (VLX)
11-19-2012, 01:44 PM
26
permalink
slownugly
Burn lean and prosper\\//
VLX
- '93 Honda Civic VLX
90 day:
51.1
mpg (US)
next i looked toward the egr passages. this one has 7 or 8 egr plugs over the holes at different locations the first pic will show them. you might have to look closesly but in the second pic you can see i already drilled out the ends that are verical and the one directly between the 2nd and 3rd runner. by doing this you can take a light and look directly through the egr passage and if you see light clearly there isnt a block and it should be simple.i lucked out even with having 240k on this intake and they were extremely clean. you can see the other side of the intake in the 2nd picture and how i set up the parts washer to run through the passages. the pictures after that you can see the fluid going through the passages and coming out of the top hole i drilled and the other side one.
last picture is a throttle body comparison. the smaller one is the vx throttle body the larger one is the d15b7 throttle body from the lx
slownugly
View Public Profile
Send a private message to slownugly
Find More Posts by slownugly
