Old 11-20-2012, 10:56 PM   #19 (permalink)
ECONORAM
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Well, that didn't do it. Not sure why. I tried soldering in a 100 ohm, then went with a straight wire. Still no joy. Better yet, when I went to remove the 100 ohm resistor I broke the wire for the resistor on the circuit board; that took some work to solder in a repair... So I made a new speed sensor disk, fixed my other wires only to discover the bulb had burned out. Sigh.
[edit] and that was only the beginning. It seems some of the insulation wore off near one of the brackets, which caused a short and blew the fuse. So, after replacing all the wiring, the speed disk, and the fuse I discover I still have no indication. Must have smoked something in the MPGuino...
