Old 11-20-2012, 11:45 PM   #58 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
With a motorcycle you can even get totally rid of any battery. 22lbs. out of a motorcycle also have a greater effect than 22lbs. out of a car
This isn't always true. Some bikes don't like to kick-start without some battery power to run the coils etc.
I had a Honda CM185T that, if you were super-special and the stars had properly aligned that morning, you could kickstart it without a battery in. Other than those rare occasions, you had to hook up something to the terminals in order to kick start it, but then it would kick off on the first try every time.
