Check if you connected (soldered in) your Zener diodes corectly, and if those resistors you've used are really above 50kOhm. It seems that you are giving falze zero signal to injestor and it stays opened. That's why you get missfire, and you can smell gasoline.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
