Old 11-21-2012, 07:03 AM   #1033 (permalink)
njakts
Originally Posted by AndrzejM View Post
Check if you connected (soldered in) your Zener diodes corectly, and if those resistors you've used are really above 50kOhm. It seems that you are giving falze zero signal to injestor and it stays opened. That's why you get missfire, and you can smell gasoline.
You are right!
I figured that out myself on my way home from university
Zener diodes were soldered in parralel with 50k resistor (67k in my case, just double-checked)
Should work fine now.
Thanks!
