Thread: GEET Reactor
Old 11-21-2012, 04:03 PM   #74 (permalink)
RustyLugNut
There is merit to this GEET device.
Originally Posted by ChazInMT View Post
@ Orion - I wouldn't believe you until we filled your Subaru with gas and then chit chatted with you for a few hours as we drive 200 miles or so then refill your tank with only 3 gallons of Gas. Something tells me that would never happen, either you wouldn't allow the company, or 6+ gallons would be added.
Here in Ecomodder, we understand where the inefficiencies exist in the turn gasoline into miles traveled equation, and unless you've somehow doubled the chemical energy potential of gasoline, this has no chance of working as claimed. Basic laws of chemistry, thermodynamics, and physics can't be changed by a fancy fuel intake system. You'd be better off letting this drop here rather than try and convince a bunch of smart people that this works. You've just flown into a hornets nest of intelligent skeptics, don't think we're just going to take your word for anything. Be prepared to explain things well.
And for the love of God, DO NOT proclaim that we need to prove to you that it doesn't work, this will instantly make you a moron of the highest order and unworthy of having a conversation with.
The problem is that it is buried under so much fecal secretion that it can be difficult to see the gold lying under it all.
The GEET device runs. That is not in question. HOW it runs is. Can it produce fuel gains? That is the other question.
If you are broadly trained and experienced you should be able to answer both questions.
