Old 11-21-2012, 06:56 PM   #95 (permalink)
sendler
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
I like the innovative case and terminal set up of the GBS and the dialed in BMS/ balancing modules/ charger that will help optimize the cycle life. The GBS cells are the same price per Wh as the raw A123 cells which still need to be packed up into a protective case and fitted with terminals and balancing boards for EV use. It would take me a lot of extra work to put together a 48v/ 100ah pack out of 80 of those AMP20 cells though it would turn out to be a bit smaller.
