I was wondering and didn't google it but I know that the d15z1 goes into lean burn easier I guess. Correct. Now with a 0bd2 0bd1 jumper harness couldn't you run a p07 ecu. All plug an play I'm assuming that the p07 would run the hx motor as they are both lean burn setups. Heck and obd1 ecu will run any d series motor I know that. I'm assuming that it would properly run it as they are both vetc e. That being said you could possibly enter lean burn more often and without the 2 mile run ect. Just an idea possibly. I you were to have e check in Cinci you could easily swap your ecu back if need be. Just a thought. I have a spare p07 if the idea crosses your fancy.
